Dark Horse
Need some help here please guys !
My 2013 Harley Davidson Fat Bob has transmission fluid migrating from the gearbox into the primary drive case at the rate of 100ml every 100 miles ! I've just drained the primary and collected 2600ml of transmission fluid ! The transmission fluid in the gearbox barely made it onto the dipstick !
My questions are :-
• Could running the bike with nearly 3 times the recommended amount of fluid , have done any damage ? ( The transmission and clutch have always worked and felt fine with the excess oil included ! )
I don't think a weeping seal would allow fluid past this quickly.
I've posted about this problem on here before but I stated that the primary fluid had not risen. At the time it didn't look as if it had , mainly due to me not being to see the level clearly !
Many thanks in anticipation.
My questions are :-
- What is the most likely route that this fluid is taking between the two ?
- If the culprit turns out to be an oil seal , how involved a job is it to do at home ?
