Kickstand?
Discussion in 'Dyna Models' started by Scruffman, Sep 25, 2016.
  1. Scruffman
    Scruffman Member
    51
    18
    10
    I have an 01 dyna, the kickstand will not go over the safety catch? it'' stop on it making it un able to rest on the stand. So I have to stop it before the catch, I know this is a safety issue and cause the bike to fall one day, but is the stand adjustable?
    thank you...
    Jack Klarich likes this.
  2. dbmg
    dbmg Guest
    Have you checked to be sure pivot nut and attachment bolts are not loose on stand. Also check spring to be sure it is in proper position.... This is something you need to correct immediately because the end result would be disastrous.
  3. Scruffman
    Scruffman Member
    51
    18
    10
    I agree, spring looks right, and will be checking the bolt soon. That's a lot of chrome to mess up..
  4. Jack Klarich
    Good deal Great answers we all learn
  5. dbmg
    dbmg Guest
    I have seen pivot bolt loosen and cause kickstand to not operate properly.
  6. fin_676
    5,779
    153
    285
    My dyna is an evo so they might have changed things a wee bit on the twin cam frame but knowing Harley's keep doing it the same way attitude they are probably the same
    The kick stand pivot and mount is under the engine so you need to get the bike supported and get under it and check the operation of the stand
