Keihin Carb Question
Discussion in 'Engine, Fuel and Exhaust' started by g2lenn, Apr 27, 2010.
  1. g2lenn
    g2lenn Member
    8
    Anybody familiar with this one? Keihin PA 40c ce14
    These are the only markings other than Keihin Japan
    I googled and came up with nothing
    50
    What's it on and what do you want to know about it?
  3. g2lenn
    g2lenn Member
    8
    It's on a 1984 FXRDG mounted using a Mikuni adapter. The engine is running to rich and I would like to rejet it.
  4. NEWHD74FAN
    8,191
    98
    19
  5. g2lenn
    g2lenn Member
    8
    Thanks for the reply's!
    Keihin says ask a distributor, distributor says ask Keihin. Keihin site does not list any carbs with a PA prefix.
    Hobbit, the adapter is intake manifold to carb so it might have had a Mikuni at one time. It is not a CV carb but butterfly type carb. Service manual only shows Keihin.
    Thanks again for the replies!
    I've spent a little more time looking over this scoot, it's been worked over by previous owners. I discovered the electronic ignition has been replaced with points. I just bought it two months ago I this is the first I've spent any time wrenching on it.
  6. fuzzy359
    fuzzy359 Member
    7
    1976 and later... keihin carb was butterfly type.
    don't know what year they went to the slide type.
