K&N Air filter
Discussion in 'Touring Models' started by ickysticky74, Apr 15, 2011.
  1. ickysticky74
    ickysticky74 Active Member
    111
    I have a 2006 FLHT with Screaming Eagle Slip ons and a opened up air cleaner box. Can I add the K&N HD-1499 air filter?
    KN HD-1499 $81.75 - Replacement Filters, Replacement Air Filter
    I have a HD model Air cleaner in it now. It seems dirty although the bike only has 4,300 miles on it. I feel the bike has sat around more than it has been rode. Bought it used this January.
  2. HDDon
    5,562
    133
    236
    I have an 05 RG and I changed the SE AC out for a K&N no problem.
  3. ickysticky74
    111
    @HDDon did you notice any difference between the two?
  4. HDDon
    5,562
    133
    236
    The SE (blue) AC was pretty new and I'm sure it's a free flow type, so I may have a little more torque but not really noticable. I changed it out because I have a K&N on my softail and already had the oil and cleaner.
  5. NEWHD74FAN
    8,191
    98
    19
    Side by side the new SE element and a new K&N oiled element will be very close to identical...but after a few washings and reoiling, the SE element will go "soft" (I have even seen some lose shape and collapse other strong intake vacuum...the K&N does not suffer from going "soft", you will see the quality and more robus design the first time you pull it out of the box. Stick with K&N, you will not be sorry. :s
  6. ickysticky74
    111
    Does anyone know where to get an air sock for this K&N air filter [​IMG]
  7. Bgdv1
    Bgdv1 Member
    95
    check the harley catalog, the one from the screamin eagle should fit.
  8. glider
    50
  9. ickysticky74
    111
    @Glider Thanks......
    I bought the K&N filter and left the bell cover off. I can actually hear it pulling in air now. Would my bike need to be remapped at HD now? It already has a stage 1 mapping at least that is what I was told.
  10. Jack Klarich
    It is sucking a bit more air now it would not hurt for peace of mind if you plan on running it this way:s
