Just a friendly reminder: Check your break switches once in a while....
Discussion in 'General Harley Davidson Topic' started by mroleg, Sep 14, 2009.
  1. mroleg
    mroleg Active Member
    151
    ....especially after long rides. When everything vibrates for long periods of time. Even more so on older bikes.
    Both my break switches were out of commission last night, good thing I checked. Rear break switch had one of two wires broken off. It is an easy fix just a matter of noticing it.
    Handlebar break switch, had one of the wires vibrated off so I had to take the switches off and re-solder it. Nothing complicated just a matter of noticing it again.
    50
    Good thought. I make it a habit when riding to do periodic checks when stopped in front of or behind a car with a quick check of the brake light and sometimes the directionals and watch in the reflection of the car for their operation. Can't be too safe out there.
  3. softailhog
    softailhog Active Member
    293
    I started the habit last year of checking the brake light with both front lever and rear pedal while the bike warms up.....so I never leave the house w/o the brake lights working!
  4. Apyle
    Apyle Junior Member
    540
    I had a problem with the adjustment on mine and my brake light stayed on. It took me a while to figure that one out.
  5. The4opps1
    The4opps1 Junior Member
    646
    3
    One of my pre ride rituals is to go through all of the safety devices on the bike that have switches. I check the turn signals, horn, brake pedal and lever, and give the bike a walk around. It takes about a minute and is worth the time...
  6. Bud White
    3,270
    As said one of the preride checks i do
  7. Safehaven
    Safehaven Active Member
    351
    Very good habit to get into before rolling down the road.
    Am doing this ever since training.
    Take care,
    Kris
  8. paulmack
    paulmack Active Member
    185
    A REAL good habit to get into. Chack out all controls and lights before taking off and at intervals on a long ride.
  9. Elmosac
    Elmosac Active Member
    174
    Your right, I know it is a good idea to do a pre-ride inspection and I am guilty of only doing it once a month or so.
    An ounce of prevention is worth a pound of cure.
  10. cdn-bigfoot
    cdn-bigfoot Junior Member
    645
    Adjustment?
    My front brake switch is causing me some problems. It keeps my brake light on unless I push the lever forward with my fingers for a while after brake deployment. It will also sometimes make my brake light flicker on as I go over bumps.
    Any advice?
