Jiffy Stand Lubrication
Discussion in 'Other Service and Maintenance' started by UncleRon, Jul 26, 2008.
  1. UncleRon
    UncleRon Member
    70
    The manual for my '04 Heritage says to use Loctite Aerosol Antiseize
    to lubricate the Jiffy stand .
    Is Loctite Antiseize just another "dry" lubricant or does it have other
    properties that make it the best choice for this job ?
    I already have a spray can of Dupont Teflon Dry Wax Lubricant . Would
    this do the job as well ?
    I know, I know it's bad to be so tight you won't by a can of antiseize :D
    Thanks.
    Unk
  2. dangerdan
    dangerdan Junior Member
    922
    I have a small tube of bearing grease that I squeeze in .
    I wiped off the excess and will repeat again next year.
  3. glider
    The jiffy stand isn't a critical part, just about any grease will do the job here and nothing has to come apart if you do it right.
  4. UncleRon
    UncleRon Member
    70
    Thanks All .
    I thought most any dry lube would do . So far this has been the easiest task yet . Hard to believe but I'm just that raw when it comes to things like this .
    I am proud to say that I did manage to change fluids in all 3 holes , change the plugs , and put on new brake pads front and rear . Did a little over 400 miles last week end and she didn't burn up or seize and did stop when ever I ask her to :newsmile108:
    Thanks again.
    Unk
  5. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,808
    133
    199
    Way to go Unk!
