Many have mentioned that their shocks have come into contact with the lifts pads used for servicing the bikes which could damage the shocks.
Try using a length of hose about 10" long and slit it lengthwise from one end to the other. Slip this over the frame rail on either side of the shock and it should give you enough height to clear the shock when using a lift. If it doesn't completely clear the lift pads, it should relieve the stress on the shocks in any event.
Naturally the thicker the hose casing the better it will work. Usually a decent piece of rubber hose or even heater hose of the right inside diameter to fit around the frame rail should do the trick nicely.
