It ain't purple
Discussion in 'Sportster Models' started by forever harley, Oct 11, 2008.
  1. forever harley
    forever harley Member
    my rear brakes are feeling a little mushy so I checked the pads and it's about time for a new set. So when I went to check the rear reservoir and the fluid was clear to amber in the bowl. Would a flush with the DOT 5 be ok to do or am I going to have to change out the rear brakes lines as well:51:
    Make sure that your bike calls for DOT 5 because they don't mix.
    The DOT 5 silicone fluid changes color with age to an amber color, just flush it out to replace the fluid with fresh fluid and bleed them out.
  3. forever harley
    It does, thanks glider
