J
		Jack Klarich
Guest
Heres a tech tip on aligning intakes, The Shovel head intake ports should be at 60 degrees, while the Evos should be at  30 degrees.  you can use a 30/ 60 degree triangle to check the alignment before torquing the  heads.  Turn the heads so the triangle touches the intake ports in 2 places before final torquing
