kburks
Hello I am in the process of installing Screaming Eagle hydraulic tensioners. After removing the cams from the support plate I discovered an inner bearing race still on the left cam and the complete bearing on the right cam still attached. I heated the stock plate in my oven and the right bearung came right out. Will I need to have these pressed off ? I'd rather remove them myself if possible. Also will I get new bearings with the Screaming Eagle upgrade kit I ordered ? I've worked on several EVO cams , but this is my first Twin Cam project. Any advice would be appreciated.
