installed new cables
Discussion in 'Transmission' started by charlie142, Sep 25, 2012.
  1. charlie142
    charlie142 New Member
    I have A 2011 Heritage that I decided to upgrade with internal wiring and s/s cables. After getting everything back together everything worked except the clutch.It won't disengage. I took the trans cover off to find the problem and I can't figure out whats wrong. Any help would be appreciated.
  2. tourbox
    tourbox Senior Member
    1,902
    173
    When you did your clutch cable did you adjust internally,behind Derby cover or just adjust the cable slack?Did you make sure the 3 balls were seated in their ramps on the tranny cover?
    tourbox
