Inner Primary
Discussion in 'Other Service and Maintenance' started by Clarklandis, May 25, 2010.
  1. Clarklandis
    Clarklandis New Member
    Would like to know how to take apart inner primary on 2007 Harley Softail Standard
  2. Bodeen
    4,647
    73
    222
    Just did my 03 RK. First thing is get the HD manual for your bike. Best money you'll spend. As far as tools goes. 1-1/2" socket for compensator nut, 1-3/16" for the clutch nut, breaker bar, maybe an impact wrench, torque wrenches in in.lb. and ft.lb., and gasket seals etc. take your time read the manual closely. Its really not that big a deal if you have some mechanical ability.
    One caution. Be careful with that jackshaft screw! It breaks, sometimes at less than the spec. torque. Ask me how I know.................
    Good luck,
    Bodeen
  3. nwbikerid
    nwbikerid Member
    Buy a manual, best $60 you'll spend on your bike, then take pictures as you go, then come back and ask questions when you get confused. What are you wanting to do anyway?
  4. Hoople
    Hoople Account Removed
    7,198
    34
    The bolts on my inner primary were special. The bolts had "o" rings built into them. The manual does say to use the bolts only once and and do not re-use. I did not replace the bolts but I did use Indian shellac around the "O" rings before re-installing. Look closely at the "o" rings for a damaged rubber ring.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Gotta ask Why are you taking it apart???
    When there, Check the Drive belt for wear and Miles on it.... Now would be a good time for a new belt if the tear down was for another reason.. Just my thought.
    signed....BUBBIE...
