I'm having a brain cramp at the moment. I can't find anything in the shop manual, owners manual or searching HDT, or web in general that gives info on the proper way to use a lift to get an Ultra raised up. Just got this new (used) Craftsman Professional m/c jack, and never using a lift before, want to do a little reading before using.
Anyone got any info they can share, or can link me to anything describing how to properly use? I saw something on HDT talking to rubber mounts that had to be used to get a Dyna off the ground. Are these required for an Ultra? Looks like the lower frame rails are low enough to where nothing would be damaged on the engine casing, etc.
Trying to find where is best lift point to get equal fore/aft balance, does bike need to be vertical as possible before raising, anything need to be aware of when lifting... Thanks
