free website stats program Induction Module Bracket Bolts | Harley Davidson Forums
mnultra
What are most of you doing with the OE bolts that you remove with the induction module bracket when installing a stage 1 A/C? Do you reinstall them or just leave them out?
I left mine out but it's bothering me a bit knowing I have these two threaded holes with nothing in them behind my air cleaner.
Maybe it just me being picky.
Open fastener holes if not allowing contaminated air into the filtered side does little if anything at all. Putting a fastener in the hole is just more weight and one more thing to work it's way loose. JMO :s
