Improper spark plug gap
Discussion in 'Engine, Fuel and Exhaust' started by Ken S., Jan 3, 2009.
  1. Ken S.
    Ken S. Active Member
    270
    What engine firing problems could be seen from too little or too much spark plug gapping.
    50
    Pinging, missing and a misfire at rpm's. Possibly hard starting too.
  3. Ken S.
    270
    non firing? After my charge and start of the bike today the front cylinder wasn't firing. By the look of my plugs, black sooty, I'm running rich, or that dang enricher is fouling it.
  4. Bud White
    3,270
    Pinging and hard starting and missing
  5. glider
    50
    Pull the plugs and gap them also see if they are wet with fuel.
  6. Ken S.
    270
    Well rats. I guess I'll get some new plugs and wires tomorrow and a can of
    WD-40 and check for leaks. And take the breather off and see if I'm getting good air.
    The front is wet with fuel. Wiped it off warmed it up with a lighter stuck it back in, try again still wasn't firing Glider.
    Thanks.
  7. Bud White
    3,270
    Check plug wires with a ohm meter
  8. glider
    50
    You could swap the front and the rear plug and see it the problem moves to the rear cylinder.
    If you replace the plug wires don't get fancy here, just the stock replacements will do a good job.
  9. Ken S.
    270
    Well, double rats. Don't know what I'll be doing tomorrow.
    Just got the call that my Mom died at 7:30 tonight. She was 87 and lived a good long life.
    Thanks for your replies guys.
    Ken
  10. Bud White
    3,270
    Very Sorry to hear that ..
