free website stats program Ignition sensor | Harley Davidson Forums
Ignition sensor
Jonk777
I look over the bike, no spark. Battery charged and voltage regulator and stator were good. Just like Jack mentioned about the nose cone area with the module. I am going to replace ignition kit that has module and coil. It is a duel fire system that was running a Dynatek ignition. The mechanical advance looks good with the springs.I didn't see any wear on the piece. Do I need to change out the mechanical advance also. With the timing being at TDC. I cant see if any where of setting the static timing on this kit, I donot see a LED light. What would be the correct timing on a basic stock 80 cubic inch evo.
