wannaride
Got the lock out no problem but to get it back in, in looks like the tab has to be pushed in but am having a hard time. There is the tab that you push in before you twist it past the lock position & then there is the tab that is the guide that makes you have to push down on the switch to go from all the positions & holds the lock in the switch. The tab that is circled will only go in when the releasr tab is pushed in & as soon as you let go of the circled tab it goes back out. The manual does not say much on those.
Here are a couple of pics from my painted inner.
Thanks for any help
Toby
Thanks for any help
Toby
