I need help!
Discussion in 'Electrical' started by George-jr, Jul 25, 2009.
  1. George-jr
    George-jr Member
    8
    I have a 97 Heritage softail and its got a screamin eagle selectable race module, So I was wondering if someone could tell me what the little switches on the bottom due? Or what they are for and adjustments? I do have a problem with it backfire's threw carb when I hit the throttle at stops but runs great going down the road and some black smoke from tailpipes when it backfires from carb.... Could ya help me out?
    [FONT=Verdana, Arial][FONT=Verdana, Arial] The module switches provide for selectable curves and rev limits. Ignition can be tuned to optimize the performance of various combinations of high performance parts. Single or dual fire capability etc. [/FONT][/FONT]
  3. George-jr
    George-jr Member
    8
    Thank you, So is there a book on the settings or something like that so I could try different settings or is this something I shouldnt mess with.... I am a do it myself man so I would like to try new things with this and know what it does if its possible?
  4. glider
    Without the papers(book) that came with it, I would leave it as is if it is running good. Maybe the dealer can copy the instructions if they have one in stock for you.
  5. George-jr
    George-jr Member
    8
    Would that be the Harley dealer? It was on the bike when I got it two weeks ago and the starter just went out three days a go so I was fixing that and then found the module so do you think that it would cause the backfire threw carb or maybe sparkplugs?
  6. glider
  7. George-jr
    George-jr Member
    8
    Thank you, Yes that helps mine is the third one down.. So now I need help with tire... My rear tire is cupped so do you know what that means?
  8. 2wheels4life
    2wheels4life Member
    20
    That is likely to be from underinflation.
  9. George-jr
    George-jr Member
    8
    So should I replace the tire and tube, The tire is worn to about 2/32 maybe 3/32 tread left and valve stem is bad on tube...
  10. 2wheels4life
    2wheels4life Member
    20
    YES! Always put in a new tube when replacing the tire, it's not worth not doing.
