I need help, cranks but no spark
Discussion in 'Electrical' started by 99fatboycustom, Jul 10, 2013.
  1. 99fatboycustom
    99fatboycustom New Member
    My 99 fatboy will crank all day long, but I've got no spark. Things that are new -- coil, VR, plugs, 30amp fuse, 30 braker. Battery at 12.4 volts. I'm out of ideas.
    dia codes
    d01clr
    d02set
    d03clr
    d04clr
    d05clr
    d06set
    d07clr
    d08set
    d09clr
    d10set
    cal05
    Any help would be great, I'm pulling my hair out.
    Thank you
  2. tourbox
    tourbox Senior Member
    1,889
    168
    Those are all Speedo codes concerning the speed sensor or speedometer. Is your bike carbed or FI? Any mods to the motor or such. If FI any fueler added?
    tourbox
  3. Jack Klarich
    Question, why the coil change and did it run before the change?
  4. Gabbin
    Gabbin Member
    15
    Try the old coil
