I got nailed !!
Discussion in 'Softail Models' started by Goofuss, Aug 15, 2009.
  1. Goofuss
    Goofuss Active Member
    131
    I am sure the this has been beat to death, but here it goes. I went to go for a ride today. I pulled my bike out and parked it. I thought I saw a stone in the rear tire, but on closer look it was a nail. :bigsmiley15:. So bottom line the tire only has 8300 miles on it. 1. do I take it to the dealer and have them put on a new tire, or do I have them put a tube in it? Thanks for your input.
    With 8300 miles on it, there couldn't be much life left in it. You have to figure what your life is worth at this point. I would replace it with a new one.
  3. Goofuss
    131
    Good point Glider, I knew I could count on you.
  4. HD-Enthusiast
    HD-Enthusiast Member
    53
    6
    GO WITH AN AVON!!!!...you will never look back...:rider
  5. Hill202
    Hill202 Active Member Contributor
    245
    You're doing better than me. My rear tire has 7000 miles on it and needs to be replaced. I'm still doing the research on which tire to get.
  6. NEWHD74FAN
    8,191
    98
    19
    New tire for your tubeless tire application. Using an inner tube means more internal heating that a "tubeless" tire is not designed for, due to all the rubbing against the inside "raw rubber liner".
    Also the reason most companies went to tubeless tires and cast/one piece wheels was to eliminate "sudden deflation" that CAN occur with tube tires verses tubeless tires (they have that soft "raw rubber liner" that makes it "self sealing" around thorns or nails that may penetrate the tire.
  7. RetiredJake
    RetiredJake Junior Member
    862
    Depends on the condition of the tire, I got over 13,000 out of my last back tire. If the tread depth is still 1/2 of the original, put a new tube in it. Otherwise, replace.
  8. NEWHD74FAN
    8,191
    98
    19
    Adding to RichardS & Glider...take the tire off and save money by doing a "carry-in" to your servicer...many will install and balance the tire FREE if you buy the tire from them. Not hard to do and there are plenty of riders & enthusiasts here to help you through...:s
  9. HD-Enthusiast
    53
    6
    Very helpful post there...we are all in awe of your wisdom and superior insight...:ap
  10. Goofuss
    131
    I know it may very, but about how much do you think I will be saving taking the tire off myself? I did once on my Sportster. I remember it was not all that hard.
