I'm curious if anyone has swapped over to a hyd clutch from a Electra Glide onto a Road King?
I'm assuming the parts are interchangeable and the benefit would be an easier, almost maintenance free, clutch pull.
You give up your clutch adjustments with this set up, It is a good set up with easier pull effort tho I miss not being able to fine tune the adjustments JMO
Searching the web it seems that kit is still available but not through Harley as if it is discontinued and is approx. $250 and up. So that concerns me. Jack's idea of a easy pull clutch may be the best option for the installation of hydraulic once removed the necessary body work is something I would not want to deal with. And it seems that the only option left is a chrome master cylinder and lever for clutch will could present another problem if you have black controls now. The easy pull kit from Harley is $50.00 for the kit.
