Humm
Discussion in 'Wheels' started by Merlyn, Oct 28, 2010.
  1. Merlyn
    Merlyn Member
    82
    Woke up to find front tire flat. Had twisted spokes put on few months back along with new tire. Got bout 8k on tire. Inflated tire checking for cause. Could find no nail hole or anything. Got out soapy water to check and found air leaking from bottom end of spokes.... Why air from there??
  2. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    You must have a hole in the tube and the spokes is the easiest way out.
  3. Merlyn
    Merlyn Member
    82
    isn't that air tight between rim spokes and tube?
  4. Blue Wide Glide
    Blue Wide Glide Junior Member
    573
    50
    Nope. If it was, you could run tubeless tires.
  5. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    When a wheel is laced, it's not unusual to have one or more spokes that protrude past the end of the nipple, and have to be ground off. There may have been a burr left on one. It takes a while but even a tiny burr will chafe a hole in the tube. that's what a rim strip is SUPPOSED to prevent.
  6. Cyclops
    Cyclops Active Member
    371
    When you have the repair made, or do it yourself, I'd want to ensure the rubber rim strip is in place. If it's not, I'd be worried about the other tire as well.
  7. HDDon
    5,542
    133
    229
    I think the others have you covered. When you have the tire off and are checking for protruding spokes and burrs on the spoke nuts be sure to run your hand all the way aroung the inside of the rim to make sure that there or no burrs left from dismounting the old tire and remounting the new one.
