How to restore chrome look to front head pipe?
Discussion in 'Touring Models' started by digs_harleys, May 31, 2010.
  1. digs_harleys
    digs_harleys New Member
    3
    I have an 05 RKC. The front head pipe (exhaust), first 5-6 inches from the head has turned gold in color. tI suspect his happened 2 yrs ago on a very hot/humid day on a long run, some of it was city, it did backfire a little on that day also. I am no mechanic by any stretch. The shop I take it to replaced the o-ring gaskets by the fuel injectors becuase they were in bad shape and might have had something to do with it runing a lil hot. The mapping was re-checked and I'm told OK. Before purchase, the bike sat for three years in an unheated airport hangar in Michigan, (only had 1,500 miles on it at purchase). It has a Power Commander, Arlen Ness Big Sucker and as far as we can tell Boom-Can Slash-up slip-ons. It is running good now, never backfires only that one day on decel and the browning has not increased in color or length. How can I remove that gold color from the exhaust?
  3. digs_harleys
    3
    Thanks Hobbit!! Gold/Straw is exactly the color! I guess I'll live with it. This site is great, especially for a novice like me.
    Thank you Glider!! I was concerned about that too. I will order the shield. I will have to live with the gold/straw color close to the head. Don't want to make things worse. Thanks.
  4. MilitaryMike
    MilitaryMike Member
    76
    Glider,
    My brand new Cycle Shack pipes discolored (first 5-6 inches from the head) after I picked up my bike and drove 25 miles. Is this normal, please let me know what you think?
    Digs_Harleys,
    I grew up in Waterford/Pontiac, where are you located and what airport are you talking about?
  5. glider
    Pretty much all pipes discolor rather fast from new with the exception of a double walled pipe or an exhaust that has been ceramic coated inside.
    Not much other you can do to stop it other than heat shields.
  6. lallsdd966
    lallsdd966 Member
    19
    I have seen two mechanics who use the very finest grade of steel wool on pipes.
  7. ZachB
    ZachB Member
    36
    I used this stuff called Blue Job on my old sporty with drag pipes and it helped quite a bit. Took away a lot of the discoloration. Not all but a significant differance.
  8. Mad Dog Jim
    Mad Dog Jim Banned
    605
    5
    I just decided to like mine that way... It shows that it's not a trailer queen! If they ever get really bad I'll just pipe-tape that part. Like the song... "Roll with it baby!"
  9. Ishmael
    Ishmael Active Member
    271
    I'm with you Jim. Unless it indicates something amiss, I really don't mind the discoloration. It's just a sign of maturity and good times gone by. Rock on!
    Ishmael
  10. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Another option is to get them ceramic coated - did this to my stock exhaust (now sold) for $160 and it not only helped a bit w/heat - looked good too...
