H hdfatboy02 Member Apr 21, 2010 #1 Does anyone know how to test a coil to know if it is burnt on a 2002 fatboy?
softailhog Active Member Apr 21, 2010 #2 See the info here for help. Testing Ignition Coil - Harley Davidson Community
G glider Veteran Member Apr 21, 2010 #3 Good work softailhog, now if we could just get others to look in the self help area too.
U ultrat Senior Member Contributor Apr 21, 2010 #4 Well i check this way use vom on lowest ohm setting check primary & secondary windings looking for continuity. passage of electrons. as a reading
