How do I keep my bike upright?
Discussion in 'General Harley Davidson Topic' started by DaveInPA, Jul 24, 2008.
  1. DaveInPA
    DaveInPA Frozen Account
    122
    I'm going to swap out derby covers on my XL883 tomorrow. However I'm sure if I remove the cover with the bike on the side stand, my primary lube will spill out. So, how do I keep the bike upright?
  2. Carroll B
    Carroll B Member
    88
    If you have a garage you could position the bike in the garage door opening and run a strap from the handle bars to the track of the garage door or install some screw eyes in the frame of the grage door to attach the straps to. This is how I plan to stand my bike up when I charge the primary drive oil this weekend. This way I can take my time and don't have to have some straddle the bike and hold it up.
  3. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    Or have someone sit on it while you swap the covers. Bike lifts are only about 100.00 at Sears... Just think, that's only twice what you paid for the derby cover...
    A bike lift is a handy thing to have...
  4. DaveInPA
    122
    The terrible piece of junk with TONS of bad reviews is 100 bucks. The nice one is almost $200. Still though, might have to get one.
  5. Buzzy
    Buzzy Active Member
    125
    4' 2x8 wood, one section of pipe threaded, one cast pipe bolt down connector. attach the connector to board, thread in the pipe, lay board flat under frame of bike and lever down on pipe till bike is hoisted on the board upright. Home depot is your friend. Also good for changing tires and a host of other repair needs. Cost is mere dollars.
  6. Bud White
    3,270
    I but a brick under the jiffy stand and it almost put it up right when i changed my derby cover
  7. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    there's probably a hundred ways to get your bike to stand up, a brick some boards, a hill, but if you own a motorcycle, some kind of lift is a must. I've seen fairly inexpensive one's at costco, and Harbor Freight. Just remember you get what you pay for, but you'll never be sorry you bought a lift.
  8. USMCCWO5
    USMCCWO5 Junior Member
    419
    I bought a lift at Harbor Freight for around $70.00 dollars. It works great and I use it weekly when I am cleaning my bike. I works magnificent for cleaning the spokes, white walls, rims, and hubs.
    Paid for itself by reducing the time spent cleaning and my bike is a lot cleaner.
  9. glider
    Check the bolts in the low cost lifts guys, they use inferior bolts and should be changed to the grade 8 that should be in there.
    I know I wouldn't want to see a harley on it's side no matter what the reason.:s
  10. DaveInPA
    122
