How do I clean my air filter?
Discussion in 'Softail Models' started by Rafaelw, Apr 17, 2014.
  1. Rafaelw
    Rafaelw Member
    50
    Stock filter 13 Heritage, 5000 miles on bike. Would like to clean myself. Thanks
    [​IMG]
  2. Jack Klarich
    Hot soapy water let air dry for stock filter
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Never cleaned a newer one BUT,,,I'd go at it with ari on the inside blowing outward. I have used Air even on the outside blowing Carefully across the veins to remove larger debris.
    Of course this is with the element out and off the bike.
    I have and many others have used the ones you can Wash in water. Swishing around in a soapy laundry tub is my favorite way, then run water from the inside thru to the outside. Removing water: I use a long arm circle wind-up motion in an out-door spot to remove excess. I lube with WD-40. I know there are other lubes out there Made for the Mesh air filters but I llke my WD...
    Paper elements are easily Replaced with a new one, think that is what HD recommends. I have still blown then with air from the inside to the out to remove dust/dirt.:s
    Light tapping also accomplishes some cleaning...
    just my way
  4. Rafaelw
    Rafaelw Member
    50
    Thanks guys!
    [​IMG]
  5. Harttoo
    Harttoo Senior Member
    2,145
    143
    Owners manual tells how to clean paper filter and advises not to oil.Check it out.
  6. glazier
    glazier Junior Member
    940
    7
    Harley filters = no oil
    K&N filters = light mist of oil
  7. deepsleep
    deepsleep Member
    6
    Stock filter...if it's covered, you should be good. Check again around 10,000 miles.
  8. 03HD883R
    03HD883R Active Member
    167
    I have a stock paper filter, and I clean it every 5k with compressed shop air.
    I've only replaced it once so far.
  9. 34thestickupkid
    34thestickupkid Active Member
    217
    Good Infomation,thanks Family
