Usually there are tabs inside the fender for the wires to channel in. Easiest access to those is to remove the front tire. There should also be an exit hole on the same side of the fender. I would say the side the brake caliper is on. You can then tie wrap the wires to the brake line up to your head light area. You can connect the power wire for the fender tip light to the Blue wire of your front turn signal, either one. The Blue wire should be the running light side of the blinker assym. I think they have a Blue(power), a Black(ground), and a Violet(left) or Brown(right) turn. The violet & brown may be just a tracer on another color.
tourbox
