patrickcarr
have a 2009 fhlxse with hd passing lamps. i would like to wire it up so the passing lamps stay on once switched to high beam. it has a two bulb center light low beam and high beam. any ideas?
I live in PA. and it won't pass Pa. inspection if you wire it that way.
Just say for a FYI. I would check with you mechanic.
You could always add a toggle switch somewhere on the bike to disable this feature for state inspections.
I'm pretty liberal with my 140db air horn, but so many times I don't even get their attention to distract from their stinking phone.
