hi rpm problems
Discussion in 'Transmission' started by trevorsr, Jan 21, 2013.
  1. trevorsr
    trevorsr New Member
    i havea panhead with a4speed ratchet top rev tec tranny if irap out 3rd gear it does not want togo in to 4th till the wheel speed comes way down. any ideas
  2. Jack Klarich
    Pull the top cover off and check the shifter dogs
  3. R. Lewis
    2,183
    5
    sorry for my ignorance here - but -- your saying the rear wheel speed has to come down... i.e. say from 75 mph to ??? 50 mph and not the RPM's of the engine. So if your out on a backroad puttin around and doing 50/60 you have no problems shifting from 3rd to 4th but out on a major highway/interstate and your trying to get up to speed - say 75 mph - you can not shift.? What speed are you having this shifting problem at? Again , if Im not understanding you , sorry.
  4. tourbox
    tourbox Senior Member
    1,885
    168
    While the top is off check your spacing on the 2 clutch gears.They are the gears that the shifter forks attach to. You really need an alignment tool for that though.
    tourbox
