suicide ride
hi all, i currently own a 86 softail with a 90 evo 1340 squeezed in it. i have a wee issue with the primary case leaking oil. iv re sealed it yet it still leaks out the top. i pulled the starter out(after being told this could be the issue) the rubber sleeve that covers the shaft into the primary case is split. would this be the cause of my leak??? any help would be greatly appreciated.
basically what i need to know is:
is this the most likely cause of the leak?
if some1 could help with a diagram link or download.
