free website stats program Help needed finding/replacing oil hose from pan to pump | Harley Davidson Forums
1997dyna
I need to replace oil pan to pump hose on a 97 FXDL - 63535-90. One dealer has it in stock, but is "keeping it for one of their own bikes". - (EDIT) Searched the internet, but having no luck. Any help would be appreciated.
It looks like installing the end to the oil pump is going to be a very difficult squeeze. So any suggestions there would also appreciated.
Thanks in advance!
You should be able to buy double wall oil hose and clamps @ any good automotive outlet, if space is a problem, try Silicone hose it is a bit more spendy but you can bend it with out much trouble with collapsing
All you need is a piece of 3/8 id hose with 2 clamps. Cut hose to length and install.
tourbox
