I'm Fabio from Italy, using Dyna FXDC 2009
The question is:
The EZ-Cams opens the exhaust valve and cut off pressure in cylinder to gain easy start, the engine no more run since i have the cams installed, supposing that all hardware is well fitted, is it possible that the ION Delphi sense realize that the engine is not good working and make the engine no run?
When the engine is cold, the engine switch on, but when hot, never!
if i use aftermarket ECM like thundermax or if i use the powercommander the Ion sense feedback to ECM is not considered and the engine runs?
Thanks if someone can help me!.
The question is:
