Help, I blew it, Tranny trouble
Discussion in 'Softail Models' started by buck484, Apr 19, 2009.
  1. buck484
    buck484 Active Member Contributor
    257
    Well, I just created a major problem. I know that if anyone can help it's HDT. I performed the 5000 mi. service on my 04 Fatboy and noticed a leak coming from under the tranny. I can't believe it but I cross threaded the plug. When I pulled the plug two small pieces of the threaded tranny case fell out. I am sick. What's next and where do I find the solution?
    Thanks for any help'
  2. Bud White
    3,270
    did you crack the case or just strip it ? if striped you can heli coil it if theres room depending where the trans drain plug is on your ride ..
  3. buck484
    257
    It's in the middle of the shocks. I believe it's just the threaded portion. Thanks for the quick reply
  4. Bud White
    3,270
    get a good look at it and see if you can helicoil it then other wise trans case .. heli coils are easy to do but you might have to remove the shocks to do it.. heli coil isnt super cheap but if done right they will hold . got a pic of what came out ?
  5. buck484
    257
    I'll try to get some pictures. The piece are very small, about 1/8 by 3/4 in. long with two threads in them. Thanks again
  6. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    there's also something called a time-sert they work well
  7. buck484
    257
    Thanks Wild, I'll look into it, I'm trying to post a picture but haven't been able to figure that out yet. Just a very frustating day. Thanks for all the help, I really appreciate it.
  8. glider
    This will show you how to post a pic.
    Harley Davidson Community
  9. buck484
    257
  10. Bud White
    3,270
    blury but that looks like a chunk of case
