free website stats program HELP!! Front cylinder not firing | Harley Davidson Forums
Bubbat450
I just replaced my cam tensioner in my 02 road king. My front cylinder is not firing. I have spark. It is fuel injected. I also replaced the all of the orings to the injectors and the intake. The injectors wiring is correct.
I did not move the crank after I took the cam gears off.
HELP!!
Time top start to re check what you already did. Look at the "O" rings to verify they are installed correctly and check the injector on the cylinder not firing up.
Sure you got everything back in and adjusted right like the push rods etc?
How do I check the injector?
I had everuthing marked.
I put some fuel in the spark plug hole of the front cyl. it fired!! So now i think it is the injector
Got it!!!!!! It was a broken wire on the injector where it goes into the connector!!!
Common problem on bikes in that era. Usually within an inch of the plug from being tied too tightly from the factory.
