free website stats program Heavy breather vs SE with K&N | Harley Davidson Forums
67wizard
Junior Member
What is the difference between the SE Heavy Breather or SE with K&N air filter? Will one help with more power than the other, or are they about the same? already have the 103 upgrade,255 cams,TTS master tune, fullsac header, reinhart slipons.
I bought my bike used with the K&N heavy breather already installed. It does it's job well but there are a couple things I dont like. The intake elbow that connects the filter to the carb is not chrome plated like the HD version is. It is only polished aluminum. It looks good for a little while but after some wear the polished surface tends to dull.
Another thing I dont like about it is the way the breather assembly is set up. With a stock air filter the breathers just discharge into the filter element. With the set up I have there is a crossover tube attached to both breathers. Then a line comes off this crossover and runs down the side of the motor and discharges into a different filter at the bottom of the bike. It took me a while to figure the best way to run this extra line. I'm not sure how the SE model solves this problem but it's not the best in my opinion.
Just a couple things to think about.
The heavy breather may cramp the cockpit area of the bike and make more intake noise. The looks on a tourer seem to be a bit out of place..:s
I don't plan to put one on my tour but a friend ask about putting one on his RK.
Thanks for the info.
Agree, it would look good on a dyna or Sporster IMO The SE with K N filter is a fine set up
