headlights yo-yoing?
Discussion in 'Electrical' started by fred815, Jun 3, 2013.
  1. fred815
    fred815 New Member
    what could be causing my headlights to start a yo-yo effect? Going dim then back to normal then dim and so forth.?
  2. Fastlinnie
    Fastlinnie Member
    40
    Sounds like losing ground to headlamp
  3. Jack Klarich
    Welcome to The Forum, along with a bad ground you could have a charging system or battery issue Harley Davidson Forums This link will guide you thru the tests, good luck and check back in:s
  4. tourbox
    tourbox Senior Member
    1,888
    168
    When you pull the head light out look at the connector for excessive heat signs. They have been known to overheat from the bulbs heat and cause the connector to warp and get bad connections.
    tourbx
