free website stats program Headlight wiring | Harley Davidson Forums
Headlight wiring
neverdown
Still working on wiring my bike. I have a skull headlight with two light bulbs. They are grounded to the headlight mounting bracket on the fork T. The two hot wires run into one wire which is connected to the ignition switch acc post.
They do not light ( the tailight works ) even when I run the wire directly to the battery positive.
I ran the ground directly to the bat neg and the hot wire to the bat pos. I have light! I am going to wire it to an on-off toggle. Should I put a fuse or breaker between the toggle and the light?
Thanks for the ground suggestion, that worked.
I mean, should I install the fuse between the toggle and headlight, or the toggle and the battery?
Thanks
