Headlight - Horn don't work
Discussion in 'Sportster Models' started by masportster, Jul 9, 2010.
  1. masportster
    masportster New Member
    A wire broke off of my directional, hit the frame and shorted out my horn and headlight - which fuse? circuit breaker or relay do I need to replace?
    2001 1200S Sportster
    Maybe try the accessory fuse or look in the manual :D
  3. fisherman124
    fisherman124 Active Member
    293
    find your fuse block pull one at a time and look at them u can see if it is blown there will not be a solid line going through the fuse replace with the same value dont go bigger
  4. fin_676
    5,776
    153
    284
    Or pull each fuse in turn and test with a multimeter
  5. NEWHD74FAN
    8,191
    98
    19
    MaSportster, welcome to the HDTimeline forum and your first post. Near the top of the page are tabs. One is Self Help Tips which lists subjects on Electrical troubleshooting...there is also Search tab which you type in keywords and find related threads.
