Headlight goes dim as I throttle up
Discussion in 'Electrical' started by jackscreamen103, Jan 19, 2009.
  1. jackscreamen103
    jackscreamen103 New Member
    Hello,
    Looking for some help if possible. Noticed that my headlight would dim on high beam as I rode along. At a stand still the light was bright but as soon as I took off it would dim again. Now after a few more times out both high and low beam flicker and go dim upon acceleration. I have also notice my high beam indicator light is starting to flicker on and off while my low beam is on. I have tested the battery for load (ok). Put a meter on at idle and have 12.9 V- 13.2 V then at 3-5 thousand rpm's it locks at about 14.2 V and never goes any higher. Not sure but believe that means the voltage reg is good perhaps. I checked all wires and grounds all appear good. I am wondering if a headlamp bulb could be the problem. Please let me know if you have ever heard of anything like this before. Thanks!!
    :wall
    If your voltage checks out, it could be a ground for the light or the bulb itself.
    Did you remove and clean the battery terminals and check the ground from the battery to the frame?
  3. jackscreamen103
    I did clean terminals and check body groud all look good. I will check my bulb next I guess. Thanks!
  4. dangerdan
    dangerdan Junior Member
    922
    Got a quick test for the filaments in the light bulbs.
    Remove the light and connect an ohm meter. Shake the bulb while observing the reading on the meter. Any flucuations would indicate a filament that is normally making a connection , but as vibrations increase continuity is lost.
