free website stats program Headlight Adjustment | Harley Davidson Forums
glider.
BOT Machine
Most lights are about the same as far as adjustment. If you remove the screw in the bottom of the headlight trim ring, you will find there is a screw at the 12 o'clock position that adjusts the beam up and down and there's one I believe at the 9 o'clock position that shifts it side to side.
I usually use the garage door to see the before and after of the adjustment. The owners and shop manual will give the distance which I think is 20 feet away and measure where the beam lines up on the door.
I generally give them a tweak to raise the beam a bit above where they should be.
