head breather
Discussion in 'FXR Models' started by wildcat, Sep 9, 2010.
  1. wildcat
    wildcat New Member
    any ideas for fixing stripped breather threads on a 94 fxr. i installed a helicoil iand its working fine for holding the carb but its not letting the breather work. the front lifter block keeps seeping oil...thanks
  2. fin_676
    5,779
    153
    285
    I dont understand how a helicoil would stop it from breathing unless it was longer than the origional thread as it breathes through the centre of the banjo bolt
  3. Jack Klarich
    I agree unless the banjo bolt is not tight or missing the crush gaskets:s
  4. wildcat
    wildcat New Member
    thanks for the info, the bolt is tight & the crush gaskets are in place. im going to take it apart in the morning, I think the helicoil is covering the opening inside the head.
