HD sercurity question.
Discussion in 'General Harley Davidson Topic' started by SeaRider04, Jun 22, 2008.
  1. SeaRider04
    SeaRider04 Active Member
    375
    I set mine as Auto Arming after 30sec of turning the ignition off, I'd like to change it back to manual arming mode but do not know how, I tried to manually enter the sercurity code to disarm it but after turning off the ignition, the system goes back to Auto Arming again. Any tip of how to disable the Auto Arming mode ? Pull the sercurity fuse out ?.
    50
  3. SeaRider04
    375
    Thanks Glider. I may read it incorrectly but I though that was for setting up the Auto arming, I have that chart in my owner manual. I'm looking for how to change the Auto mode back to the Manual mode.
  4. glider
    50
    Take a look at the table at the bottom and #6 what it tells you. I believe this is what you are looking for, how to change the feature.
  5. SeaRider04
    375
    Silly me, yep that what I'm looking for. Thanks Glider.
  6. glider
    50
    OK then, you had me wondering there:s
