HD Screamin Eagle Heavy Breather Question
Discussion in 'Softail Models' started by crossfire3006, Jun 25, 2009.
  1. crossfire3006
    crossfire3006 Member
    7
    I looked around the forum and didn't see anything related to my question so if this question has already been asked, I apologize. I have a Stage 1 kit, power commander, and V&H Big Shot Staggards on my 2002 Deuce and want to put on a Screamin Eagle Heavy Breather. I already had the power commander mapped for the stage 1 kit and V&H exhaust. My question is when I put on the heavy breather, do I need to do ECM calibration? Thanks for any help.
    crossfire3006
  2. Bud White
    3,270
    if anything you would have to change the power commander settings
  3. vaibhavcoder
    vaibhavcoder Member
    42
    I think power commander setting is all you have to change.
    Noddy
  4. elkhunter149
    elkhunter149 Account Removed
    134
    I have a 2008 Road King with the screaming eagle cone K@N style exposed breather, also true dual Rienharts, with the high prefomence baffels. I have had to make no cem adjustments, It will compensate it self for the larger amount of air intake and output. I know its been a big topic about adding a power unit or not. Everything I have tried, read, and talked to people about its not needed.
    My 2 cents
  5. glider
    While this is partially true about it compensating itself, it compensates back to the very lean mixtures that EPA has imposed on us. Added fuel will make it run much better and a bit cooler as well.
  6. JRFatboy
    JRFatboy Account Removed
    7
    I just bought the HD Heave Brether for my '05 Fatboy carburated,
    I havent put it on yet, im waiting for my new pipes to come in and
    im going to do it all at once, I am told I need to re-jet my carb from 45mm to 48mm.
