Hayden M6
Discussion in 'Transmission' started by 90FXRS, Jan 26, 2014.
  1. 90FXRS
    90FXRS Junior Member Contributor
    459
    10
    Since the weather here (EDIT) it's time for some maintenance and other stuff on the bike. I got a Hayden M6 from a friend who sold his bike and never put it in.
    I'm wondering if anyone here has any experience with this unit and any suggestions, tips or warnings?
    Moderator Note: Please read our rules on language
    [note]
    HDTimeline Language Policy - Harley Davidson Community
    [/note]
  2. HDDon
    5,542
    133
    229
  3. 90FXRS
    459
    10
    I posted this as I was heading out the door to the garage. It's installed. Had to grind a little on the shim to get it to slide all the way against the C-bracket. The instructions say this might have to be done.
    It keeps more tension on the chain as compared to the stock adjuster......I guess this is where the springs come into play as things heat up.
    The scooter has 30K on it. Only took one shim, the thin one, to get the 5/8" from shoe to shim.
  4. Bodeen
    4,643
    73
    221
    Do you detect a different noise with the M6 from the primary? I know when I installed mine it created a different sound for the primary. Part of it being that mine was acceptable on the tight side of the tolerance with out shims. Like you, I discovered the chain to be tighter than the by the book adjustment. It still has a different sound to it. that I thought I would get used too.
  5. 90FXRS
    459
    10
    Bodeen, I haven't lit fire to the wires yet. I forgot to go past NAPA and get the ATF for the primary. Rivera Primo Pro Clutch........ATF.
  6. Bodeen
    4,643
    73
    221
    Let us know, I would be interested if you can hear the difference in the primary sound.
  7. 90FXRS
    459
    10
    Definitely sounds different. I called Hayden and they said it would take a couple hundred miles to seat the chain to the shoe.
    Probably be my last post.
  8. Bodeen
    4,643
    73
    221
    Mine did quiet some after a few hundred miles. It still has a different sound that I have grown used to. Like I stated before mine was at the tight side of the spec with no shims. That alone would cause a little more noise.
  9. Jack Klarich
    Probably be my last post.[/QUOTE]
    Question? last post? What does that mean?
    Curious:s
  10. Bodeen
    4,643
    73
    221
    Curious:s[/QUOTE]
    I think he meant last post on this subject. At least, I hope that is what he meant......
