Harley oil cooler
Discussion in 'Oil' started by BEN KRAVIN, Aug 28, 2012.
  1. BEN KRAVIN
    BEN KRAVIN New Member
    I HAVE A 2003 ROAD KING. IT HAS A HARLEY OIL COOLER ON IT, installed by Harley. Does the oil filter adapter (part #26297-99) on those over time, from removing and installing oil filters, rotate to a position making it difficult at best to remove and install filters past the crank positioning sensor? There's also a chance it was mounted in that position originally, by Harley. If so how can I rotate adapter back to a position where I have the needed clearance? Has Harley come up with a fix for this?
    Thank you,
    Sgt. Mike DiaBen, U.S.M.C.
    Semper Fi
  2. RibEye
    RibEye Junior Member
    993
    61
    I strongly recommend one of the offset adapaters by Jagg: Oil Filter Adapters | Jagg
    Get the anti-rotation bracket, that will keep the adapter from rotating when you are working with the filters.
    Enjoy,
    Rich P
  3. propflux01
    propflux01 Active Member
    217
    Mine (2003 Ultra) has teh adapter as well, and I have to remove the crank sensor each time I change the filter, but mine is set in one place and does not move. I have heard that I am not the only one who has to do this each change when the HD adapter is used.
