Gurgling Slip Ons
Discussion in 'Touring Models' started by hd4evr, Aug 17, 2010.
  1. hd4evr
    hd4evr Banned
    181
    My new Rinehart slip ons make a gurgling noise when I let off the gas, or when I shift. It's not a backfire, just a gurgling noise. Dealer did the install, but I did notice he re-used my old exhaust clamps. Is this gurgling sound normal?
  2. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    I know mine gurgls a bit too, but should be normal - unless you have a leak somewhere. Did you check for any air/soot coming off the clamp joints? If you feel pressure, or see soot then there's a leak, but it should sound more like popping & pinging.
  3. BikeSAG
    BikeSAG Active Member
    322
    38
    5
    hd4evr.....I get the same when I'm somewhere between on the throttle (under acceleration) and not completely off the throttle. Sometimes it sounds more like a chirping sound. I assumed it was normal but after thinking about it my 2005 Sporster never did it.
  4. BikeSAG
    322
    38
    5
    Steve07....what is wrong with the tried and true method of using a couple of potatoes stuck in the end of the tail pipes?:lolrolling
  5. R. Lewis
    2,183
    5
    In my case - I would get sidetracked on what I was doing when the smell of french fries hit the air!!!!! :D
  6. hd4evr
    hd4evr Banned
    181
    I don't know. I can't believe the pipes are supposed to sound that way. I sound like an aquarium, you know, the bubbling air pump, with a tiny backfire every once in awhile when I let off the gas, or even when I shift gears. The dealer installed PCIII, but I'm not sure it's set right. Bike runs great, but the bubbling noise just sounds weird. I've seen a lot of Rinehart slip ons on other bikes and they don't sound like mine.
  7. TQuentin1
    4,737
    142
    Check this:
    Muffler Leaks - Harley Davidson Community
