twicecam Active Member Dec 28, 2008 #1 If I disconnect the ground cable do I have reprogram my alarm codes:dknow
NEWHD74FAN Experienced Member Retired Moderators Dec 28, 2008 #2 Should not be a problem as long as you do not activate the alarm prior to disconnecting.
G glider Veteran Member Dec 28, 2008 #3 Be sure to turn the key on before disconnecting the cable You'll find out why.
NEWHD74FAN Experienced Member Retired Moderators Dec 28, 2008 #4 glider said: Be sure to turn the key on before disconnecting the cable You'll find out why. Click to expand... Eh...other than getting a charge out of it? :newsmile053:
C cdawg55 New Member Mar 22, 2009 #6 I am installing a stage one air kit on a 2009 Street Bob. Does anyone know where the maxi fuse is and how to remove it?
