I am replacing my handlebars on an '09 Superglide, one side is bent (don't ask). I also decided it would be a good time to replace the grips as well. I have gathered together the required parts, the 56081-82A handle bars and a set of 56006-88C "multi-fit" cushioned grips. My research tells me that these should fit the Dyna. My concern is that the left grip is very loose. It came with a tube of glue but before I attempt to install it, I want to be sure that the fit is correct. Reading other's experiences on the internet, it seems like the left grip should be a force fit. This one flops around and would fall off easily if not glued on. Does this sound right? The bars measure 1" with my calipers and the grips are supposed to fit 1" bars.
