zeroroadkill
Does anyone have the specs of the green fuel injectors compared to the red or black injectors? I believe that the black injectors are the stock injectors for the TC88??? I believe I have the stock injectors and 38mm TB on my 95" motor. It's running rich, but still pings. I have 50PSI on the fuel pump and SE heads and 204 cams. Are the green injectors too much for my application? Should I be using the red injectors? My PC USB III map shows I'm running rich in the 2000-2800rpm range and I still ping. I've dropped the timing by -3 degrees with little help.
Tks
BOBB
2000 Road King FLHRI
95"
flat top
SE heads
204 cams
V&H true duals
V&H oval slip-ons
PC USB III
Tks
BOBB
95"
flat top
SE heads
204 cams
V&H true duals
V&H oval slip-ons
PC USB III
