free website stats program Grease fittings | Harley Davidson Forums
Grease fittings
markols1
Hi all Marc here form OZ how are you all going? Question where are all the grease fittings on a 2010 fatty cheers summers here time to ride.:panic
If you have a grease fitting it will be on the neck, turn the wheel to the right and have a look
Generally it's only the baggers that have the grease fitting because the tubes of the frame on the other models are not close ended at the neck like baggers are so you would be filling the entire frame with grease. There's a possibility this may have changed on the later models but not sure. If you have a fitting there from the factory, then they have changed the greasing applications.
On my Heritage the fitting is on the right side of the steering neck. It's easy to see if the wheel is all the way to the left.
